early 1970"s chrysler 120 hp
cwd60tx
can anyone tell me on how to change a impeller on my 120 hp chrysler outboard motor its about a 1971 engine Thanks Chuck
Frank Acampora
Re: early 1970"s chrysler 120 hp
Look at the top of this page for the sticky: step by step impeller change. Even though the instructions are for the one piece lower unit, your earlier two piece lower is very similar.
Only major difference is if you have a very early lower unit, then there will be a six inch long bolt inside the exhaust snout and you MUST use a 5/16 inch 12 point socket to remove it
cwd60tx
ok thanks Frank I will check it out today
