Early 70's 70-85 hp Lower Unit * Fixed *
Rugid
Last year on my last outing on the lake my lower unit would slip out of gear once I started to bring on the rpm's or when she was under load ( towing a tube etc ). So this winter I disassembled the lower unit and ground the clutch dogs even and inspected the forward and reverse gear. The forward and reverse gear are in excellent shape. I still could see the original tooling marks.
This year I got her put all back together and got her out on the lake. Same issue. Any ideas or what I could look for? Did I install it incorrectly? Your help is appreciated.
jerryjerry05
Re: Early 70's 70-85 hp Lower Unit
Need pics of the dog and gears.
Possible need a cable or shifter.J
1983rinker
Turn the shift linkage one full turn counter clockwise. That work for me
Rugid
Could this be a " spun prop"? Because I can back off the throttle just a hair and she reengages. But there is no audible "clunk " like when I first put her into gear. It's almost seamless as it disengages and reengages.
Rugid
It turns out it was a spun prop.
kj0874
Re: Early 70's 70-85 hp Lower Unit * Fixed *
Tell me about the problem you had...I have an early 80's Merc 70 and it feels like it falls out of gear [and goes into neutral] at full throttle or even getting there on the upper end. Not sure if that could be the lower unit going out, or if it is what you have.
Rugid
How I knew or should say I was guessing it wasn't the gears was the transition from power underway to where it would go into " false neutral " was smooth. There was no clunk as when you first put it into gear when starting underway. Also after closer examination of the prop I could see where she was spinning. Hope this helps.
