early 80"s 115 tilt trim replacement
bigbill007
hi guys i'v just purchased a complete tilt and trim with transom mount for my evinrude 115 , taken off the old one they look identicle only to find the 4 bottom bolts (2 on each side of the leg) and two on top of the whole assembly that connect the transom mount and steering to the motor are different.
the old assembly has slightly wider mounting positions than the new one but the rest of the assembly is the same. i was wondering is it possible to remove the steering arm assembly of the old one and retro-fit on the new , has anyone ever come across this or know anything about these 2 different types. the only visible difference i can see besides the width of the mounting points is the old one comes with 2 little covers that conceal the 4 bottom bolts on the leg.
any help would be appreciated heaps i'v had this motor on for nearly 4 months and still havnt taken her out
ezeke
Re: early 80"s 115 tilt trim replacement
What year PT&T did you buy? Part # or pictures would help.
bigbill007
just went outside to take some pics before i post i noticed the new one says 3 cyl on the bach of it and the old one doesnt. i hope that doesnt refer to the actual motor becuase i have a 115 v4 pics will be up in few mins
ezeke
Generally the PT&T units changed in model year 1992, so the transom brackets are different.
ezmobee
It does, and there's your problem...... The 3cyl units won't fit a V4. At least the mounting plates are different. Not sure if anything else is.
bigbill007
thats gr8 lol i think i'm still gonna try changing the steering arm it might work coz the rest of the assembly is pretty much the same the tilt trim motor and all so it should still have enough power to life my motor if it works im still working on the photos there almost up . thanks for the quick reply guys
bigbill007
notice the dark piece sitting on top of the new white assembly has slightly wider mounting points, and also the bottom of the steering arm
ezeke
Why not just pull the PT&T unit out and see if it will transfer. Do you need to replace all of those parts?
ezmobee
To Ezmobee: I don't think so because, for example, the 1989 70HP uses the same exact manifold as the 1990 140. which is the same as on the 1983 115 but has superseding part # 391099 to 398110.
Figures. I should really stay the heck out the engine forums. I just know that the mounting plates were different for the older style units. Thanks for the correction.
bigbill007
i had a bad experience removing the first one snapping the bolts that connect the sides to the tnt inside the tnt unit so im not gonna put ma self through that again lol. also while on the subject of parts from diff engines
i'v heard you can replace the carbs from a 140 and fit onto mine as they share the same displacement is this true and if so what year models is this available on
