early 80's bubbleback 140
What is the general consensus as to the reliability and performance of the bubble-back 140's from the early 80's? I know that when they started prop rating them in in 85 they magically became 115hp motors. Any thought or comments?
Thanks
Jason
emdsapmgr
Re: early 80's bubbleback 140
The early 140 crossflows were a sought-after engine. They had some nice tricks that the other engines did not have. High compression heads, large carbs, bubble back exhaust and intake filler blocks. OMC made these V4 engines by the tens of thousands back then and parts for them are still readily available. The 140 looper replacement engine in 1985 is a much heavier engine than the crossflow, with larger displacement. When that looper 140 engine debuted, OMC changed the crossflow: dropped the intake filler blocks and re-rated them at 115. The 85 115 still used a high compression head, and the bubble back exhaust, so the performance difference compared to an older 140 may not be all that apparrent. All crossflows can accumulate carbon around the piston rings with age, so an occasional decarb will keep the engine running healthy.
tashasdaddy
i have a 1977 140 run like new.
well thanks for the input. after looking over my 1989 88spl I determined that the motor was not going to making another season and I didn't want to be caught out on the water with a dying motor. I found a very clean 1984 bubbleback 140 that I will be hanging it on the boat this weekend. Compression on the motor was all 120+ and it started and ran great. I am thinking that this will give my hull a new lease on life.
Now all I have to do is figure out how to change my screen name?
Thanks again
Jason
tashasdaddy
by PM. request a mod, to ask admin to change it.
