squirly
- Joined
- Nov 11, 2013
- 20
Hello everyone!
Have a couple of quick question regarding a crankcase. Im working on an early 80s Evinrude 35hp block, replacing all the gaskets and seal etc. Ive sprayed some wd40 inside the crankcase last night and this morning I've noticed the wd40 seeping out from the side of the crankcase (the block is on its side on the bench). Does this mean i really should open up the crankcase and reseal it, or is it just because of the penetrating properties of wd40 that it manages to seep through the case?
The reason for the initial rebuild was a rusty top spark plug, the result of a worn gasket in the exhaust buffer plate. After taking off the bypass cover i noticed some specs of rust on the crankshaft also. Not much, but a few specs here and there. What are the chances of rust damage to rollers/bearings inside? I pulled the lower seal and looked at the lower bearing and it looked perfect. I should also mention that the previous owner had bored out the cylinders and replaced pistons, which makes me think the crankcase/shaft mustve been rebuilt at the same time. Im by no means a specialist but the oversized wiseco pistons look in very good condition and don't look like they've been used much before the exhaust gasket failed and the engine was put away.
Question is, shall i go for a full rebuild and check the crankshaft while I'm almost there anyways, or should i reassemble and hope for the best? What parts will definitely need replacing once i open up the crankcase and get to check the shaft? I have another 35 block, and also a 78 20hp so i was thinking not to rebuild and just replace the block when this one gives up. But id like some advice to help me make up my mind.
Thanks in advance!
Thanks in advance!
