The other day my son and friend were running down the river on plane. It suddenly jumped out of gear as if it went into neutral. Since then it will not go into forward or reverse. I removed the prop thinking it had spun, it seems to be fine. With the prop removed I worked the shift rod up and down manually. It doesn't seem to matter what position the rod is in. The prop shaft spins freely in both directions. For a lack of better words, It acts like it is stuck in neutral. What do you think went wrong? Also, I am a back yard mechanic by default. Is this something that can be diagnosed and repaired by your average back yard mechanic?
