Easy question for the pro's!!!!!
Karl_Childers
How many GALLONS PER HOUR can I expect to burn with a 1988 200hp 2.4liter black max? I have this motor on a V20 Wellcraft. I am using a 17 pitch prop and at WOt get 6000 RPM.
I know fuel consumption is not a linear thing, so I am curious about WOT consumption and 3000, and then again at 4000 RPM respectively.
I have done some searching here but all I can find is specific MPG questions. I know I can do the tests myself, but asking someone here that has already done it is a lot cheaper :)
Thanks for your time!!!!
Rob
ENSIGN
Re: Easy question for the pro's!!!!!
If you're going to worry about the gas leave the boat at home'it just takes all the fun out of boating.A digital flow meter in the fuel line will tell you how much gas you're using.
Karl_Childers
That's not really helpful, or an answer to my question. If you have so much money that you just don't care how much you are putting in your tank, then I am sure there is another Forum on the internet specifically for you.
j_martin
What Ensign was trying to tell you is that it'll burn about 20 gallons per hour at WOT. Because of planing inefficiencies, you might get a bit of reprieve MPG wise at lower throttle, but when she starts to sink or plow, it goes way up.
Also, the general formula of 1 GPH/10 HP is common knowledge, and that fact has probably been stated about a thousand times on this forum alone. Try searching for information.
hope it helps
John
Karl_Childers
Before you decide to flame me, you might try to read my original post. First of all, if you read my original post (which you clearly didn't) you might have seen that I did do some searching before I posted. I am not interested in what "some guy down the street told you" I am interested in REAL RESULTS. That is, what people have found for themselves.
Secondly, I am really unclear how I was supposed to derive that information from what ENSIGN wrote. Would please highlight in ENSIGN's post where he told me 20 GPH at WOT?
The long and the short is that this is a forum to exchange information. If you want to be rude to me or be a smart ***** I will hand it right back to you ten fold, because there is absolutely NO NEED to be rude or smart.
j_martin
Yer new here, aren't you. Chill out.
The information you got is about all that can be obtained without knowing much more about your boat, setup, etc. What can be said is that old carbureted POS will burn a lot of gas.
I know, I own one.
hope it helps
John
robert graham
Go to: Yamaha Outboard Performance Bulletins and check for the motor and boat combination most similar to yours, gives MPG, GPH, MPH at any given speed. I'm not sure if Mercury provides a similar performance chart but the Yamaha chart should give you some useful information to study. I know before I found this chart I used to cruise around 2500 to 2800RPM's, but actually the best mileage and efficiency for my boat/motor combination is 3500RPM's. Hope you find this helpful and good luck!
kingfish62
Here is a quote from another web site:
"Figuring out fuel mileage on a car is simple. Fill the tank completely, jot down the current mileage and drive until the tank is near empty. At the next fill-up, note the miles traveled and the gallons of fuel it takes to refill the tank. Then divide the number of gallons of the second fill-up by the miles traveled.
It's a different story with a boat. Miles aren't easy to measure on water, so fuel consumption is measured in gallons per hour. You measure fuel efficiency in pounds of fuel used per horsepower developed per hour. The pros call it "brake-specific fuel consumption." This makes it important to know that gasoline weighs about 6 pounds per gallon.
On average, an in-tune four-stroke gasoline engine will burn about 0.4 to 0.45 pounds of fuel per hour for each unit of horsepower. Likewise, a well-maintained two-stroke outboard burns nearly 0.6 to 0.8 pounds of fuel per hour for each unit of horsepower it produces. These figures apply to carbureted and fuel-injected engines, but not to direct-injected engines such as Mercury's OptiMax and OMC's FICHT models.
Confused yet? Look at the mathematical examples below that show the figures for a 50-horse engine, and it should become clear.
Keep in mind that these formulas apply when the engine is making peak horsepower, which usually is near wide-open throttle. Fuel consumption will be decreased at cruising speeds. Also remember that newer engines with loop-charged intake systems, fuel injection and direct injection will yield higher fuel efficiency than older, cross-flow fuel systems that were manufactured as late as 1990. Cross-flow systems are antiquated and wasteful compared with the technology available today.
To apply these formulas to your boat, just plug in its horsepower rating and multiply the top, then divide the result by the bottom. For two-stroke engines, another way is to take the total engine horsepower and divide it by 10. As you can see, this formula is simpler to calculate and easier to remember. You don't even need a pencil and paper. It's just not as accurate as the formulas above. The result represents the approximate gallons per hour the engine will burn at wide-open throttle. For example, a 150-horse engine will use about 15 gallons per hour. Though these figures represent averages and can vary from 10 to 20 percent, they'll put you in the ballpark so you can plan a long-distance cruise."
electricjohn
A rule of thumb for a boat is...HP divided by 12.5= gallons per hour. Now if you could just find a way to figure your HP at less that full throttle.
Yepblaze
The poor guy asked for pro's. Lets show some credential here.
Most of the pro's are on the job charging for their prowess.
