Can someone verify me one thing about this armature: should the round brass-coloured end-piece be placed on top of the armature shaft (it's currently very firmly seated in there) or should the brass piece be a part of the electric motor's top cap, serving as a bearing-type insert in which the armature head should be placed (and freely rotating in)?
To answer this one I think you should have disassembled one of these, so any advice telling me to check out some parts lists or blowout pictures are unnecessary, since I've already looked at those and I'm starting to think that the brass piece shown in picture should not be there... of course right now I have the boat in the water with a malfunctioning PTT so I can't really give any additional info right now.
My personal opinion is that the motor sucked some salt water some year after being manufactured in 1985 and then the brass cap ended up seizing on that armature end and thus got taken off its original position. I just would to get a confirmation if my hypothesis is correct or not, before dismantling the unit for the 3rd time. The PTT unit works intermittently, when working it sounds and works great but most of the time it makes a bad grinding noise and doesn't move up or down. When grinding, the motor also heats up quite a bit. The armature looks a bit bad, I know... The engine is a 4cyl Mercury 75 hp, 1984.
Best Regards,
Tatu, Helsinki, Finland
Best Regards,
