Do you currently have a prop for this outdrive? If so are there any numbers on the prop...<br /><br />For what it's worth, I'm thinking that a pin type prop for a Volvo outdrive may be the same, but not sure.. <br /><br />Might try to contact Michigan Wheel... http://www.miwheel.com/MIWheel/profile/main.htm
Let's try this again, the last one terminated early.<br /><br />I have the prop, but have not checked it for numbers yet, I'll check that first. Then I'll cary it to a prop shop and compare it to the Volvo props.<br /><br />I appreciate the information.<br />Todd
