Re: Eaton outdrive risks?
they have a pretty good reputation
Marysville Marine in Michigan has a good parts supply, but it only takes one part to put you in dry dock and waiting and watching eBay etc...
if the boat comes with spare drives it helps, but if your hobby is collecting spares and you eventually fill part of a shed, you can have your own warehouse as a lot of vintage drive people do
there were different models and some only did well behind a 4 cylinder
the vintage car analogy doesn't work that well for a few reasons imo:
1. every tire shop in town has a tire for your old car should it get a flat... but if you knock a blade off a powernaut propeller, will the local prop shop have a replacement?
2. if your old chevy loses it's reverse gear, do you crash into the parking lot wall and risk injuring your passengers? or run over a person who was skiing behind you and needs to be picked up?
3. if your 409 breaks down, will your car drift out to sea?
4. do you have to paddle that chevy several miles if it breaks down?
I know a dozen places that could weld up a set of exhaust headers for your 409... but if that Ford is some rare FireballSix or some weird rare thing, there may just not be an exhaust manifold for it in the world, and no one will make you one. And unlike a car, water passes through the exhaust and if it's ever been in salt water, well...how is 47 year old cast iron going to look?
If it's a 289 or 302...something could probably be worked onto it.
If the seller can't provide info like model numbers, run away.
