Eaton outdrive
Vintage Boat Guy
I bought a boat recently that is a 20' open fishing boat, it has a 289 Dearborn Interceptor in it that is attached to an eaton outdrive, I was told the motor ran and kit has new oil in it and new impellers. Should I replace this set up? Switch sterndrives? Or will it work just fine.
Re: Eaton outdrive
Ayuh,.... Welcome Aboard,.... It's old, 'n parts might be tough to find, but if it's in good shape, run it til it pukes,...
Got any pictures,..??
Vintage Boat Guy
Re: Eaton outdrive
I have the water pump for it and the hard copy manual, as well as an electronic copy for these kinds of motors
Re: Eaton outdrive
Does this outdrive have a built in water pump?
Ayuh,.... I ain't sure 'bout yer's, Mine are it's bigger sisters, 'n they use a motor mounted raw water pump,...
I Believe yer's does too, but I ain't sure,...
southkogs
Re: Eaton outdrive
What year is that rig? Never heard of one before.
Vintage Boat Guy
Re: Eaton outdrive
1966 is what I was told the boat was but not sure of the year, I know there is a water pump on the motor but is one built into the outdrive? Just want to know if I have to replace the impeller
Re: Eaton outdrive
Ayuh,... If there's a motor driven raw water pump(rubber impeller), there ain't 1 in the drive,...
it don't need 2 of 'em,...
The circulatin' water pump(cast iron impeller) don't count,...
Vintage Boat Guy
Re: Eaton outdrive
There is a bronze pump that mounts on the front of the motor like a straight drive inboard
