If I put the wrong lub in it would that cause ti not to shift at all ?Silvertip said:It is true that electric shift lower units require a special lub which ensures proper shifting. It is not grease. Evinrude/Johnson dealers have the lub. If you check the label on most lower unit lub containers it will state specifically that it is NOT for use in electric shift lower units.
