ECM 555 fuel balance test
silver_power
Hello. I just want to ask if the diacom scan tool can make the fuel injector balance test when the engine is equipped with the ECM 555. My engine is a 350 Mag mpi (2009) which is semi batched fired. This means that it triggers the injectors per pairs. (2 injectors at a time). It would be useful test to know if the fuel pressure drop is equal to the 4 pairs of the injectors. So, does anybody know if this is possible?
thank you very much.
silver_power
I have the rinda diacom, and at the function tests the injection balance test is included but I thought that this is applicable only for PCM555 . So I was wondered if anybody with ECM555 has try to perform it. I will for sure try it ,just for test, to check if it works. But I have to wait about a month to go to boat.......
thank you.
