Edge trim
Hottip
I want to cut a 2" hole in the inner fiberglass liner and put in some rod storage holders. After I get the holes cut I want to have some dort of trim on the inside of the cut. I was thinking of car door edge moulding but it won't make a 2"radius turn. Does anyone know or have any ideas that will give the holes a finished look?
Re: Edge trim
the stuff your looking for is called Quickedge? Trim made by stanpro and it comes in 100 foot rolls and a few colors
http://www.perfectfit.com/15976/154.../Standard-Double-Lip-Edge-Trim-Quickedge.html
the trick with it is to heat it with a heat gun and it will make the radius you want , took me for ever to find the stuff to replace it on a center console and the seat cooler base you can call the people from the link above and see if they have shorter pieces
