Educate me on outdrive gear ratios please.
further
Would like to understand how to determine what outdrive would work. My existing outdrive is an SX and the nameplate is completely illegible. If I wanted (at some point) to replace it with a duoprop, what do I have to look for? Do they need to match ratios? Would any SX DP work? How do I figure out what ratio my current drive is?
sorry if this has been asked before... I couldn’t find in my search attempts.
Thanks
On VP's, ratio is in lower. 5.0 and 5.7 get the 1.95:1, V6's get the 2.15:1, Big Blocks get the 1.78:1.
further
So if I have a 2004 5.0, my drive will be 1.95:1? So would I be able to just swap the entire drive out with a SX DP that is 1.95:1 of the same vintage if I found one?
You really only need the lower unit
further
Ok understood but if I had a complete upper and lower SX DP I could just swap?
