newport dave
- Joined
- Nov 21, 2004
- 458
After doing a little research I discovered that it was very easy to make a simple, but very useful, Marine EFI Code reading and clearing / Base Timing Tool. And you could make it for under $1.00!<br /><br />Materials needed:<br /><br />One 12volt resistor type LED light<br />One small paperclip cut in half<br /><br />Thats it!<br /><br />
<br /><br />This home made code tool works every bit as well as the one I paid $50.00 for. It will work on most marine EFI systems with the ten pin DLC. This includes Mercuruiser, Volvo, Crusader, PCM, Indmar, and one or two others.<br /> <br />How to hook it up:<br /><br />1) Ignition key OFF<br />2) Remove the cap from the Data Link Connector (DLC)<br />3) Slide the LED into the female terminals of position E and F on the DLC, making sure that the positive side goes into terminal F and the negative side into terminal E<br />4) Turn the ignition key to the ON position (LED should come on)<br />5) Insert the half paperclip into terminals A and B This puts the engine in Service Mode - (you will hear fuel pump come on, and code will begin to flash on the LED)<br />6) Read codes by observing LED flashs. If the self diagnostic system is working it will flash code 12 one flash, pause, two flashes, long pause it will repeat three times. If other codes are present they will flash in order of lowest to highest.<br /><br />
<br /><br />For more details on how to read codes, clear codes, what Service Mode is, how to set base timing, etc. refer to appropriate service manual.<br /><br />LED Details: The LED that my scan tool has had 122K ohms resistance. I went to a local electronics store and got a LED that was labeled T 13/4 12v LED w/resistor. It measured 164K ohms. Im not sure if just any LED would work, but I thought the resistor type would be the way to go, and it worked fine.<br /><br />I dont recommend making and using this tool unless you have a good idea of what you are doing. Im not sure if you could do any damage with it, but its certainly possible. <br /><br />Dave<br /><br />PS. I know I will probably catch heck from DonS for this.
