efi de-carbing
sinkunit0
i want to de-carb my 200efi.unfortualey where i live sea foam is unavaidable .i have mercs spray for this, but i,am unsure where to spray it.on the can it says through the carbs but i don,t have any.do i unscrwew the oxygen sensor and spray through there?
jim dozier
Re: efi de-carbing
You don't have a carb but you do have a throttle body which for purposes of decarbing would work. I don't see why you can't remove the airbox and pour the decarb solution into the throat of the throttle body (which looks a bit like a carb it just meters air not fuel). The EFI fuel injectors will do what they do while you pour it in. If I'm wrong somebody will says so.
