Having recently replaced the breaker points and coil on my Mercruiser 170 with a Pertronix Ignitor and Flamethrower coil, I would like to get a solid 12 volts to the ignition coil. I have circumvented the ballast resistor but I still get only 9 volts at the ignition coil and at the ignition key switch. However, if I disconnect the electric carburetor choke, the voltage at the coil and ignition switch jumps up to 12 volts.
Is this normal? What is the likely culprit and fix? I've got a 1986 170 (3.7L/470) Mercruiser
