electric fuel pump problems?
piratedude
have brand new engine in boat w/ @20 hours- ran out of gas in boat today and when gas put in - wouldnt start- checked elec fuel pump output and nothing... pump runs but no gas- are these pumps crap? 20 hrs and fails? can i put a mechanical pump on engine? this is a new 350 vortec carb engine. also the connectors on pump are crap too...push on type the dont work! have to tie wrap wires on.. i belive this is a carter? pump.
ozziebob
Re: electric fuel pump problems?
Two things 1- This sight is supposed to be for mercury outboards..
2- More than likely by running out of fuel you have dammaged your electric fuel pump and it is not a case of being a crap pump.. These pumps use the fuel for cooling and lubrication. By running them dry it only takes seconds to minutes to destroy them. In the Mercruiser service manual it will instruct you to prime the fuel pump with a hand pump (fuel primer bulb) before starting a newly installed or dry fuel pump. A crook pump is not the only explanation but is the most likely given what you have said. Best of luck with you repair!
mikael.block
hi
try to check your fuel lines.... maybe they are blocked...
try to blow air back in the tank...
mikael
