electric fuel pump wiring
bgiese
have a 1985 Chris Craft i/o bow rider and due to a cracked block have changed the original 305 out for a indmar 350, I used the distributor and wiring from the 305 to hook this all up and the problem that I'm having is powering the electric fuel pump that came on the indmar engine, I have the 3 prong oil switch that is tee'd to the oil pressure sender on the back of the block for when the oil pressure is high enough to send power thru to power the pump, but for some reason I don't seem to be getting power to it from off the start side of the key switch, I had downloaded a generic wiring diagram that Don S or someone had posted awhile back and had followed that when wiring this all up and for the life of me I cannot find it and to make it worse had done all this last fall, so suffering from memory loss I can't remember how I had powered it off the start side of the key switch. the fuel pump is a carter marine fuel pump and using a Holley 600 dual feed carb
thanks for any help
bgiese
