electric fuel pump
waterdog85170
ok, here we go...88 four winns with omc cobra. friend bought it used, has a 350 vortec block without fuel pump provisions. previous owner installed automotive elec pump with no oil pressure cutoff. trying to keep my buddy alive, i need to fix this. so i need part # for a fuel pressure switch and a diagram to wire it correctly. by the way, we are ordering a holley MARINE pump for it too. thanks.
Buttanic
Re: electric fuel pump
Look in the Holley catalog, they also have the switch and wiring diagram.
Don S
Here is a diagram from Mercruiser using an oil pressure switcht to put power to the fuel pump when there is oil pressure. Note, there is power to the pump when the starter is engaged. This is necessary if the engine doesn't start the first time or the fuel has leaked or evaporated out of the carb.
