Re: Electric Fuel pump
I am rebuilding a 28' 1972 Winner with two 5.7L GM motors. I have the motors out and trying to decide whether to switch over to electric fuel pumps or not. Both motors are 2004 models. I have seen so many different pumps with different pressures/GPH that I am not sure what to go with. Any suggestions on pumps? Thanks in advance
Welcome to iboats.
First point... What ever you use must be marine/USCG certified. Resist the urge to use the cheap junk off the auto parts self, as they may leave you with a big hole in hull (and you) once the fire from the explosion is out.
Second point... What are you working with? Carbureted? Fuel injected? Who marinized the engines? Merc? Volvo? PCM? Etc...
Third point... You say they are 2004 engines. I could be mistaken, but a 2004 marine engine is not going to have a provision to use old mechanical fuel pumps. Unless you are using GM automotive crate engines such as the 290 HP, 2 piece RMS, non-vortec engines...
If they are in fact true marine engines, I would probably use what ever configuration the original manufacturer used for pumps, and adapt them to your boat.
