Electric shift stringer omc stern drive
Dirtymike20
I got a boat and the lower unit is cracked. But I also have another boat same motor.. same lower unit.
My question is can I just pull the whole drive off the boat? The throttle cables are disconnected already, figured I'd just swap both drives and not mess with lower unit.
Its a v6 3.8l 1984 hammond omc stern drive
Both boats are identical.
Can you just pull the bumpers off and take the bolts where the drive pivots up and down? Then pull it off. It doesn't have a drive spline it has the two gears that mesh together. Like I said the shift cables are already disconnected and pulled through the housing.unnamed.jpg
southkogs
'84 drive wouldn't be electric shift. Should be mechanical.
BUT, if both are the same lower unit: pull your drive, stick your good upper on top of the good lower, reinstall drive after maintenance and enjoy.
You can swap the entire drive if you know the upper and such is good on the other drive.
Redrig
yes you can just swap over the drives. If they are both 84's they are not electric shifts , they are mechanical shifts.
how are the ball gears on both of them ? anything below 50% wear should be replaced. So if one of the boats has better ball gears swap them over as well.
and be very careful with your shift cables while removing the drives, that cable is very expensive to replace
Dirtymike20
Thanks for the advice!
Dirtymike20
Thanks
Dirtymike20
So I'm assuming that there is nothing else that would be attached to the housing/ or running through?. Other than the shifting cables..like hoses or wires? I dont really see anything.
Redrig
there is a clip that has to be unbolted before removing the drive.
Its right where the shift cable goes through the intermediate . be sure to remove the clip or you will rip the cable
Dirtymike20
Okay thanks. Is it pretty noticeable and accessible? Or literally where it goes through?
Also. Inside of housing. (Boat side) or outside the housing. (Between drive and mount housing)
Redrig
on the outside , yes its noticeable. Right where the cable passes through into the boat.
tilt the drive all the way up and you have easy access
