Electric shift stringer trim pump setup
froggy1150
I am adding a trim setup to my ford/omc 190 hp drive. I have 2 different manuals and neither have the hydraulic schematics. I have the pump, both Ford rams and all the brackets. I also got some lines but they are bent and broke so I can't tell how they were routed. There are 2 ports on the pump does top pump go to top ram and bottom to bottom? Would anyone have some pics or drawings. I would prefer technical schematics showing all parts in circuits but I doubt those are available.....
southkogs
Look around HERE, under PARTS, select STERN DRIVE from the drop down and navigate to your drive.
You should also be able to find the shop manual at outboardbooks.com. I don't know the hydraulic system at all.
froggy1150
Yeah that shows parts but not where they go in detail. As in what port on the pump is up/down. I have the factory manual and seloc. Neither has hydro schematics. Got wiring but not the other half.
