Re: Electric trolling motor
A lot of variables there, Pulldog. Speed and the capacity of your batteries are the most important.<br /><br />Let's say you have a pair of 100amp/hour deep cycle batteries and you set your troll speed so that the motor is drawing 10 amps. It will use 10 amp/hours per hour until the battery voltage starts to drop, probably after about 8hr.<br /><br />So: The slower you troll and the bigger your batteries, the longer you can troll. If you crank the motor up to top speed, of course, you will use your batteries up much quicker.<br /><br />Good, 100 AH batteries should cost you $80 to $100 each, and the 74lb Genesis with Auto Pilot about $1200. Figure about $200 more for a good, on board dual bank charger.<br /><br />Good luck.<br /><br />Red sky at night. . .<br />JB
