I have a 1972 302 Mercruiser 5.0. V-8
Keep in mind that my boat doesn't seem to want to start. It rotates a couple times but that's about it.
My question is about my ignition coil a 12v w/internal resistor.(It's not a Marine ignition coil because at the time I bought it I didn't know if there was any such thing as a marine ignition coil.....come to think of it I still don't)
Anyways, I notice the eyelet on the wire leading to the positive side of the coil was a little tatered so i decided to replace it. After I had done so(with solder and heat shrink wrap) I wanted to find out how many volts were going through the wire, 11.50v. Now get this. When I connected the wire to the positive side of the ignition coil and tested the wire again the voltage dropped to about 4. What's the deal?
Chris
Chris
