Electrical breaker box and wiring question
brother chris
I am re-wiring my travel trailer today, or tomorrow(once I figure out the correct way to do it).<br />A friend of mine works in the sign industry and knows about electricty and wiring. <br /><br />I have a breaker box with 3 - 20amp breakers in it. <br />I also have a breaker box with 3 - 15amp breakers in it.<br />And I have enough 15amp wiring to re-wire my trailer. <br /><br />My friend says I should use my original breaker box that came with the trailer(the one with 20amp breakers) and run my 15amp wire. <br />He says it is okay and that the chance of a fire, or overloading it, is slim to none.<br />My other friend has given me the other breaker box with 15amp breakers in it. <br /><br />I want to install the 15amp breaker box with 15amp wiring. Makes sense to me. <br /><br />Three questions: <br />1. Do you think my friend is wrong with his adivce? (using 15amp wire with 20amp breakers)<br />2. Which breaker box would you use?<br />3. I am running a house size fridge, hot water tank, computer, TV, PS2, lights, etc... Pretty much everything you would normally run in your house. Is 15amp enough for all of this, or should I get 20amp wiring and put the 20amp breaker box in?<br /><br />Thanks for any advice. <br />B.C.
Ron G
Re: Electrical breaker box and wiring question
I think youll be pushing it using 15 amp wire with all that stuff,lights will be fine on 15 amp,i would rather have 12 gauge on 20 amp for fridg and waterheater.i would go with the 20 amp box and 20 amp wiring,12-2 with ground,
sangerwaker
DO NOT USE 20 AMP BREAKERS AND 15 AMP (14 AWG) WIRE!!!!! <br /><br />Yes, the CHANCE of overloading and impending fire is small, but is your life worth it?
brother chris
Thanks for the input.<br /><br />Well, this just blows. <br />I do not want to go and spend another $100 on new wire.<br />Are you sure 15amps will not suffice.<br />I will go and buy the wire, if I have to....I just want to make sure it is warranted. <br />Because, like I said, I have the 15amp breaker box and enough 15amp wire to do the job.
dolluper
Anything with a motor [compressor] will need the 20 amp like your Frig,waterheater. If that is an electric waterheater it probably is running on 2 20amp breakers locked together when you switch them on and the other for the Frig I'am guessing.If you run the 15 amp'ers and if you don't cause a fire you will be running to the box to trip the breaker every time the frig starts.Old systems with fuses had to use time-delayed fuses to counter act it<br />So do it right buy some 12 guage wire and run 20 amp'ers
brother chris
Okay, I trust your opinion. I will go and buy the 12 gauge wire, and install that. <br />I don't want to keep flipping switches. <br />Thanks fellas.
crab bait
there's is/mite be alittle more to it.. <br /><br />first off,, how are you goin' to power the 15 amp box..?? what make is it..?? <br /><br />will it require the use of TWO breakers of the 20 amp box..?? what make is it..??<br /><br />also,, what is already exsistingly wired from the exsisting 20 amp box..??<br /><br />mite be better off to buy a 12 space panel,,they are very cheap,,remove old 20 amp box an have 12 spacer in it's stead.. <br /><br />hook-up old wiring an new ..all in same box..mite even use the same breakers.. most are interchangable.. some aren't..<br /><br />then you can run all new on 15 amp wire.. but have all the heavy amp drawers on their own circut.. <br /><br />read lable on h2o tank ..see what volts an amps it is..
brother chris
Originally posted by crab bait:<br /> there's is/mite be alittle more to it.. <br /><br />first off,, how are you goin' to power the 15 amp box..?? what make is it..?? ]We have power running from the house, out to the barn, which we ran to my place. The make is FPE(Federal Pioneer)[/b] The breaker box has 2 double breakers, and one single breaker(all 15amp) <br /> <br /><br />will it require the use of TWO breakers of the 20 amp box..?? what make is it..?? The 20amp breaker box has 3 20amp breakers in it. All General Electric. <br />also,, what is already exsistingly wired from the exsisting 20 amp box..?? Nothing....I took all the wires out of it and I am moving it to the livingroom. <br /><br />mite be better off to buy a 12 space panel,,they are very cheap,,remove old 20 amp box an have 12 spacer in it's stead.. I am not sure what these are <br /><br />hook-up old wiring an new ..all in same box..mite even use the same breakers.. most are interchangable.. some aren't..<br /><br />then you can run all new on 15 amp wire.. but have all the heavy amp drawers on their own circut.. <br /><br />read lable on h2o tank ..see what volts an amps it is.. The water tank does not say how many amps it draws....only says the volts are 240. It is a 12 gallon tank, but I might be getting anohter bigger one.
heyttown
Some good questions for sure....<br />Most important now that we got you using #12awg for 20 amps, is how are you planning on feeding the power to this breaker box.Wire size,breaker size......If your friend led you in the incorrect direction with the breaker box,I would hate to see the same thing happen.
heyttown
Home depot,Lowes sells a ITE/seimens 12 breaker(spaces)panel for around 50 bucks.....<br /><br />If you exisitng panel only has 3 breakers in it and its filled up...<br />You will need at least a 2 pole breaker for your 240v heater,so that takes up 2 of the 3 spaces.....1 space left is not enough to feed all the lights,fridge and whatever else you have.....
ketron47
I would suggest that you check with a trailer dealer. Many code (NEC) requirements for house wiring is not applicable to trailers. If you have a large water heater (ie; house size) you would need to run 220 volts, #10 wiring, with a double 30 Amp breakers. A regular size stove would require #6 wiring, with a double breaker which could run from 60-100 Amps. If its an older trailer, be sure to check that it wasn't wired with aluminum wiring; if so and you use copper wiring, then the breakers would need to be replaced. There are many other considerations.<br />Again, best to check with a dealer. Good Luck
brother chris
Thanks ketron. <br />I am not using the old wires. <br />I am installing all new wires. The old ones are crap.<br />The water heater is not a "house size" one, just half that size. The stove is gas...so that is okay. <br />I am going with 20amp wire and 20amp breaker box. I hope this will work....it should....I think.
craze1cars
Originally posted by brother chris:<br /> <br />I am going with 20amp wire and 20amp breaker box. I hope this will work....it should....I think.
This entire thread just sorta scares me. This is going to come across rather harsh, and I honestly mean no disrespect, but based on your questions it appears you don't have a lot of knowledge of electrical wiring. 15 amp branch circuits have little or no business in any home or trailer and shouldn't even be considered. so I'm glad you're upsizing to 20 amp box & wires, and you may be OK, but your questions are very vague and it's impossible for anyone here to know for sure how to advise you....there's math formulas written to determine max loads on a branch circuit, special grounding and wiring requirements for trailers, and you may be very limited on how much you can draw by the main feed wires coming into the trailer...it's been asked a couple times here but I haven't seen your answer yet...what gauge are the feed wires coming into the box? And how big is the breaker on the other end? THIS INFORMATION IS CRITICAL. <br /><br />Also, the gallon size of your water heater has nothing to do with the amount of current it draws. Being a 240V, I can pretty well guarantee you that 12 guage (20 amp max) wire is NOT going to be sufficient to feed a water heater safely. You will most likely need 10 gauge or larger for the water heater circuit. If you undersize ANY wire it will get hot, and your trailer may burn to the ground.<br /><br />If this were a house, code would likely require a dedicated circuit for 1. Fridge, 2. Bathroom (GFCI), 3. Bathroom lighting, 4. Bedroom (AFCI), 5. Kitchen counters, 6 and 7. General lighting and outlets, 8 and 9. 240 volt hot water heater. So I believe you need at least 9 spaces but I could be wrong on this (most likely I've missed something as I admit my knowledge of codes is not real current.) Will you have a microwave? If yes, usually a dedicated circuit is recommended. That makes 10 circuits. And people in trailers often want space heaters in the winter, but I don't know your situation. Does this trailer have heat? A/C? From the little you've described, I'd guestimate you'll want at least 60 amp service....and that's why the incoming wire size and breaker size is so important. To further complicate things, how LONG is the feed wire? Voltage drop may be an issue if it's a fairly long run from the main. If I were wiring this myself for a family member, I'd probably consider running 100 amps to it with a 20 space box. The extra up-front cost is minimal.<br /><br />Obviously that all sounds like MASSIVE overkill, and it might be. Afterall, it's just a travel-trailer. But current is current, and wires can only handle so much current before they start to overheat...that's the most important thing to understand.<br /> <br />Electrical codes are not written just to make things difficult and expensive...they're written to prevent death. I really feel you should be hiring a licensed electrician to do the work. That way this trailer will be less likely to burn to the ground in the middle of the night.<br /><br />I sincerely wish you the best in your project, but elecricity needs a LOT of respect. If you still want to go forward with doing this yourself as I imagine you will, I urge you to go to the library and check out a copy of the NEC (National Electric Code) and study it at length...even an outdated copy will get you in the ballpark for safety although it won't guarantee local code compliance which is usualy more stringent than the NEC. If it confuses you (and it will confuse you) start asking specific questions about what you don't understand.<br /><br />EDIT: I just read your profile...I see you're in Canada (I know DUH...I shoulda known by your signature!! :D ) Everything I wrote refers to the United States. But I imagine Canadian codes are similar because the laws of physics are certainly the same. I'm not sure what the Canadian equivalent of the NEC is...but I'm sure it exists.
heyttown
Thats not harsh..........That is right on.Peoples lives are at risk.<br /><br />This forum is great for advice,and im sure if given the proper information myself and a few other licensed electricians can get him on the same page....<br /><br />Were here to help,but you have to help us along the way.
brother chris
Thanks for the info guys. I appreciate the responses. <br />How about I start over. <br />The power is coming from the main breaker box, in the house, which is 100amp mains. <br />There is existing wire that has been laid to the barn out back, behind the house. <br />Our plan is to direct that wire to my breaker box in my trailer. <br />I am going to use the 20amp breaker box, which came with the trailer, and run new 20amp(#12awg) wire to the duplex receptacles in the trailer. <br />Here is a picture of my breaker box. <br />It has room for 8 - 20amp breakers, but I only have 3. I am going to go and buy 3 more. <br /><br />
<br />
<br /><br />If this picture is not good enough, I can take a close-up one, if it helps. <br /><br />Are those the space panels(on the right and left) that crab bait was refering to? <br /><br />Thanks for all the input guys. Trust me, I do not want my trailer to burn down.
craze1cars
Originally posted by brother chris:<br /> There is existing wire that has been laid to the barn out back, behind the house. <br />Our plan is to direct that wire to my breaker box in my trailer. <br />
The box itself is probably going to be fine for your use if you can buy some more breakers for it. BUT before we even get to the box there's a bigger issue....exactly what gauge and type is the "existing wire laid out to the barn", and approximately how long is it? And how many conductors are there? For instance we need to know whether this might be "200 feet of 6 gauge 3 conductor with ground" or "100 feet of 8 gauge 2 conductor with ground." This is the first and most critical piece of information to know as it is going to dictate the maximum amount of current and voltage the box in the trailer can handle. The 100 amp main on the house doesn't really matter much either, but how big is the one breaker on those wires running to the barn? And is it a double or single breaker (110 or 220)?
brother chris
The wire from the house to the barn is between 150'- 200'. It is on a single breaker, which is a 110 breaker. <br />The wire has this printed on it...endurex. 14/2 <br />That is all I can read from the part of the wire, which is exposed. It has 2 wires and bare ground copper wire.
craze1cars
That's exactly what we needed to hear. Unfortunately it's bad news...and time for a significant investment...<br /><br />That's 14 gauge wire, 2 conductor with ground. WAAAAAAAY too small for what you're planning to do, and it's only 110 volt. That's the same stuff as your current 15 amp wire that we already determined early in this thread was too small to even wire a single circuit. Plus the voltage drop over that length is definitely going to be an issue. It certainly wouldn't feed the entire trailer if you want more than a small TV and a couple light bulbs. Absolutely no hot water or fridge.<br /><br />You can't do a thing until you run new wire all the way from the breaker box in the house to the trailer. Get ready to choke on the price...if you need 150+ feet of appropriately sized wire (I'd guess you'll want 6 gauge but we'll need to do a load calculation on EVERYTHING you intend to run in the trailer to know for sure), and since you have at least one 220 circuit, you need 4 separate conductors (2 hot, 1 neutral, 1 ground). I haven't priced that type of cable in a long time, but I bet you'll be looking at several hundred dollars just to buy the necessary wire to bury in the yard. And depending on code, it will either need to be direct burial UV cable (which is expensive), or more likely needs to be encased in conduit the whole way.<br /><br />I strongly urge you to hire an electrician for this job. This is not a DIY project that can be adequately learned by chatting over the internet.
crab bait
that barn wire is WAAAAY WAAAAY too small.. <br />14-2 is 15 amp wire.. that's it.. 15 amp wire.. an at 200 ft,, it's even less then 15 amp..<br /><br />you need at least 6-3 and a ground..an that's pushin' it..with the length-of-run..<br /><br />an 6-3 not 6-2 cause it's a sub-panel an requires a white wire ( nuetral )..<br /><br />i just gotta say,, your gonna be way-over-your-head on this.. please find someone local that can help you.. <br /><br />you'll laugh but<br />i go to a tavern in the day around 4 o'clock.. buy a beer an start talkin'.. someone's an electrican..
brother chris
Well, thanks for the info. <br />My friend is positive that he can do this himself, and does not think we need to change the wire.<br />I am going to call an electrician and tell him about the situation I am in , and see what he says. Then I will have my bud talk to the guy too, that way he will know why I want to make sure it is done the right way, the first time. <br />I'll keep you posted as to what happens.
