I have converted form a stock 55 amp alternator to a one wire 10si universal 200 amp alternator. I had to change the fuel pump from alternator connection to a oil pressure switch to turn off the fuel pump when the engine is not running. The choke wire I have wired to a 12 volt source. I have also upgraded the postive cable to 1 awg wire going thru a 200 amp circuit breaker then to a pro mariner 1 alternator 2 battery isolator. I presently have to alternator case ground going directly to negative bus bar. There is a smaller wire going from the negative bus bar to the engine block.
The problem I'm having is low amps coming out of the alternator. At 800 rpm's I'm getting about 30 or less amps. Rev the engine to 3000 rpm's the amp are a little less but it not constaance amps.
What I'm i missing? Had the alternator tested and they said it perform as it should. I hope I explained what I trying to do.
