1975 135HP Johnson
I have a question about how the Electrical Components Bracket mounts on to the engine. Mine is such a mess with different sized bolts extra washers here and some missing ones there. As well as an ill-fitting grommet that is really messed up.
I bought new grommets and then noticed from the parts drawing that there are six washers involved (one is floating off by itself in the drawing and I didn't catch it before). My bracket as mounted does not have any bottom washers installed, just one (or two) on top of each bolt. But the washers currently installed on the engine are different sizes. The parts drawing only shows one size and one part number.
I am not too clear exactly how the bottom washer fits in but I assume it is under the rubber grommet so the rubber does not wrap around the posts sticking up from the engine. Once I get the washers and install them, is the bracket supposed to be really tight or will it have a lot of wiggle in it? How tight will I tighten the bolts? Are these grommets just for vibration isolation or do they serve another purpose?
Thanks
Thanks
