electrical fault
fletcher
help ! i've got a 14ft fletcher arrowflyte with a merc 60 hp.problem is that the bilge,horn and lights don't work.i've check the wires for damage and the 4 fuses under the steering wheel and all looks ok.any ideas where i should look next please ?
belairbrian
Re: electrical fault
Don't know your particular boat but it sounds like a disconnected wire or a fuse. If you don't have a Digital Multimeter get one. Harbor freight actually has some decent ones. I carry one in the boat and the RV.
Most DC circuits are pretty simple. 12v from battery to switch (fuse in between) with switch on 12v to gizmo (light, pump, horn) ground wire from gizmo back to battery. anything not connected gizmo stops working.
With 3 items all not working I'd look for a wire not connected near the battery first
Fl_Richard
Look for a re-settable circuit breaker in the back by the battery compartment.. Just guessing
