Re: Electrical for Dummies Part 2
the ground an neutral is the same thing back at the transformer.. both get tried to XO on the transformer... the neutral is made by/in/thru the transformer secondary side .. <br /><br />the reason it become separate.. is because the neutral is a current carrying conductor..the return path from the load ..load is anything that is using the electric power.. lite bulb, motor, toaster, appliance,ect.. <br /><br />the ground is not a live wire.. <br />it's just a wire that travels along with the rest an gets bonded to every box, housing, metal, encloser, conduit, any metal object that the live wires pass/run thru or near, or by..<br /><br />a electrical circut is basicly a controlled short.. 2 wires connected together via a 'load'..<br /><br />TO, THRU, & RETURN is a circut..<br /><br />the power usage of the load keeps the circut from blowing...<br /><br />have a problem.. the stray current hops on the ground wire.. the ground wire is not connected to the load.. the circut blows because ya got a hot going an a ground wire ( now in the loop ) returning unabaded ( loadless) back to the panel to blow the breaker..<br /><br />that's why a GFI is so importain.. the ground wire ( three wire ) system is really only for equipment protection an not human protection.. <br /><br />the "unabaded ( loadless ) back to the panel to blow the breaker " is true but since your gettin' shocked ,, YOU BECOME THE LOAD.. an the breaker mite not ever trip .. being's you make a pretty good toaster..
