haulnazz15
- Joined
- Mar 9, 2009
- 3,720
Alright Ladies and Gents, I've got a small electrical gremlin to hunt down. Took the 'Twain out for the first water test since the rebuilt 351w and transom rebuild this past weekend. Boat fired up off the trailer without an issue, was a little finicky with shifting related to the shift-interrupt, but it still worked decently.
The boat ran great for about an hour, which consisted of varying rpms between 1500-2800 or so. No major issues to speak of. Within 1/4 mile of the boat ramp, I pulled the engine to idle/neutral and it stalled. No big deal in and of itself, but when I went to restart, I turned the key and got a thunk from the starter. Then nothing, and to add to it, the blower would not turn on. The bilge pump, and nav/anchor lights did operate however. Anyone have a clue what could be happening regarding the starting and/or blower?
Short list of new electrical items:
New battery
New battery positive AND negative cables (24" each)
Fresh rebuilt starter
New Rhule inline blower
We had an issue with the blower when we installed it, and I thought I fixed it by running a new lead from the fuse block to the blower switch. It functioned before startup and was running fine until the stalled engine mishap. I have a multimeter and have already check the continuity of all of the electrics from the blower/fuse block and found no resistance in any wire.
Bad battery? Possibly bad wire from starter solonoid to starter? (Remember it's a Ford so it has the separate slave) Why would the blower stop working when it is on the same fuse bus as all of the other instruments/switches?
New battery
