Hello, I've got a 1989 Force 125hp that I just purchased used ( I'm not a mechanic ). When connection the battery I know the cables are getting hot. After some testing with my multi meter I've found the that issue appears to be with the starting motor, when it test resistance from the positive terminal on the starting motor with the ground on the block I'm getting a beeping ( sorry not sure what the correct term is ). When testing I disconnected the main power wire from the starting motor. So it appears that it's grounding out. Does this mean I need a new starting motor? Or any other ideas how to fix this?
Hope this makes sense, thanks!
