Hey all, so after ressolving my starter and fuel pump issues(carbed 1996 4.3 merc won't shut off with key), i started troubleshooting his non functioning trim gauge. The gauge had worked before the partial submersion of his engine. it now reads full up all the time which i believe means there's an open in the trim sender circuit. While following the wires and moving the harness this way and that looking for wire breaks, i happened to notice that all gauges were now dead, no power and were no longer illuminated. Further investigation led me to the fuse panel under the helm where i found a burnt 20A fuse in the circuit that's connected to the keyswitch. I replaced the fuse and it blew again immediately. I know i have a short somewhere thats causing this but am unsure as to where it might be- i can't find any obvious breaks in the harness, no missing insulation. i know this is a hard one to ask for help, but please, help. any typical wiring diagrams for helm wiring, and thoughts as to common causes of shorts in the ACC circuit. In addition, i'd love to know what color wires run from the engine compartment up to the trim gauge in the helm so i can follow them back to the sensor. Thanks in advance for any help you may be able to provide
