I have a 82 merc 40 hp that i need some help with. The description is a bit long so bear with me.
Heres the deal, i was having an issue with a weak spark. Stator tested good for resistance and DVA voltage when disconnected from switchbox however when connected it was only putting off <10v on the black/yellow at the pack. Determined this to be a bad switch box so replaced with a new cdi but still the same issue persisted. Called CDI and they wanted to test out the box to be sure it was not faulty from the factory. Box tested good, so the next possible culprit is the stator even though initial testing shows that its good.
Replaced the stator with a new one along with the new switchbox and bang it is fixed - at least for about the first 20 min. of testing. Voltages are all within range >180v on the black/yellow while running and the pack is putting out a solid 150v to the coils. After making some adjustments to the timing figured i would go back and recheck voltages.
That is when the black/yellow at the box began showing ~90v and the pack to the coils is now back down to ~2v just like with the old stator.
I need to understand how this could happen. Both coils, the stator, switchbox are new. Trigger tests out good. The majority of the wiring from the harness up has just been replaced. Everything is testing good on its own and for that matter everything was working properly for a short amount of time after replacing the stator.
Seems to me the stator has just fried again somehow, but rechecked the resistance and it is still good.
PLEASE HELP IM READY TO USE THIS MOTOR FOR AN ANCHOR!
