Gyp-sea
- Joined
- May 11, 2010
- 18
okay...still stuck trying to get my old motor to start. it's a 1962 johnson rk24 electramatic 40hp. it has a push button starter that replaced the old key start. everything worked fine when i first got it a few weeks ago and now when i try to start it i get nothing! i can jump wire the two big post on the solenoid and the starter kicks in with no problems, so it's not the starter. i have gone under the dash and re-connected all the wiring as some connections looked a little sketchy...still nothing. i cleaned up all the connections from battery, to starter, to solenoid, to dash connections...nada. i went back to the solenoid and jump wired the battery post to the small ignition post and didn't get any response, not even a sound...to me that said the solenoid was shot. just bought a brand new one and installed it...still no start.
the only thing i have not tested is the controller box. i have read a few threads on here that say that can be a problem...some little switch inside that tells the motor it's in gear and will not allow the starter to kick in? problem is, i don't know if i have that kind of feature on my old 62', and if i do i sure don't know how to test it. any suggestions?
