Electrical Problem 08 Four Winns H200SS
4WinnsH200SS
I am a new owner of the above mentioned boat. The previous owner had a custom stereo installed- actually he left the Sony head unit and installed some sub-woofers, amps and a bunch of tower speakers. He also installed a second battery with a switch allowing Battery 1, Battery 2, Both, and Off.
Normally I turn the battery to off when I am done boating for the day. While at the lake for the past week, I left the switch on over-night. One battery was weak and barely started the motor. I also noticed that day that the stereo would only work at fairly quite volumes and would cut out if I turned it up. When I got home I took both batteries out to have them tested, assuming I had a bad battery. Both batteries tested great. I put the batteries back in the boat and now I have absolutely no power. I am pretty confident that I have put the batteries back in correctly. There is a fuse back by the motor that is called, "Helm Power" that is kind of a push button. Should that be in or out? It wont push in- Any help would be appreciated!
