bullets_full
- Joined
- Nov 8, 2008
- 6
OK. I took my boat out yesterday and started it. It idled for a couple of minutes and then died. I brought it home and had the battery tested at a local auto parts store. The battery failed. So I bought a new battery, started my motor, let it run for about 15 minutes and turned it off. I tried to start it back up and NOTHING!!!! I turn the key and no sound whatsoever.
Battery is good (brand new)
battery cables are not corroded or bad
ignition switch works.......all gages come on when key is turned
I cannot find a fuse box anywhere to check for blown fuses.
Could the starter have just crapped out on me?
I have an inboard OMC Cobra 3.0 4 cylinder engine.
Model number 302~DG~MMDA
Serial number T01266454
Any information would be appreciated.
