1992 Rinker 235 FestaVee with Merc 5.7L I/O; dual batteries with switch on both; shore power when docked with battery charger and frig on. <br />After running the boat for the day when I shut down the temp gauge often stays at whatever temp it is at (140-150). If I turn it right back on it seems stuck at that spot. When I click the ignition on and off (without starting)the next day the guage drops to zero and works fine. When I was out yesterday I noticed that my tach stayed at 650 when I shut down after docking. Switching the ignition on/off without starting corrected that and it went to zero. I recently changed the t-stat from 160 to 140. While I had the 160 in the temp ran up to 160-170 so I know that the guage appears to work ok. Any idea what is causing this? Thanks
