Re: Electrical Problem
If you hook the battery up backwards 9 out of 10 times you will blow the rectifier, if you did you better change it or you may burn up the stator, rectifier is fairly cheap the stator is mega bucks, fire it up and see if it is charging the battery, if not check the rectifier. Hooking up a battery charger backwards or using jumper cables will do the same thing
