Can someone explain to me if or how problems with the stator/rectifier cause a motor to stall?<br /><br />I have a 1996 90hp Johnson. It has been having problems that I believe are either the rectifier or stator... the motor will be running ok, then suddenly the tach will go screwy and it will die without warning. <br /><br />This is just ignorance, but I thought that if the battery was connected, even if the charging system failed the battery should keep the motor going.<br /><br />An explaination would be greatly appreciated... I'm scratching my head. <br /><br />thanks,<br />mike
