Only had this motor for 4 weeks and havn't had much to do with marine stuff before. I have 2 issues that may be connected.
1st - Tacho is not accurate. Works some times, but most of the time it is reading way to high.
2nd I have a miss at low rpm. - Cleaned electrical connections on control lead and replaced one faulty spark plug lead (open circuit when moved into different position). This has improved, but definatlyu not fixed. Seems worse once hot. Motor stalls mostly when back at boat ramp (hot).
Could the two be related? Seems to miss lots more when tacho plays up.
Any help
Any help
