Electrical Problems
sea2sea
Hello - this is my first time to this forum. Tried to see if my problem was in the archive, but no luck.
Here's my problem - appreciate any help in advance. I have a 12-year old Mercruiser 5.0. Last weekend, it ran just fine - this weekend, it would not start. The only problem I noticed when it would start last weekend was the trim would not raise the engine when I was in shallow water - I had to use the trailer button to trim up the engine, but could lower it just fine.
My first thought when it wouldn't start was the batteries were dead - that was not it - I confirmed that each was well charged. However, when I went to reconnect them, I noticed that when I put my batter selector switch to battery 1 (the starting battery) it would only register 12 volts ( I usually see about 13.4 when I start). When I switched the battery selector to battery 2 (which was not connected) it also gave a reading of 12 volts.
When I turn the ignition key, I get a "quiet" single click. The starter was replaced last year. All the gauges work
Finally, when I was trying to see if there was any obvious wiring issues, I noticed that the red/purple wire coming out from the alternator was disconnected. But it did have a bullet-type push connector. From my research, I "think" this red/purple wire goes to the slave solenoid.
Questions:
1. Since I was getting a voltage reading from my dash gauge from battery 2 even though battery 2 was not hooked up, could I have a bad battery selector switch and/or battery isolator that is causing the engine not to crank?
2. Is the fact that I can not raise my trim up using the up button (but will raise if I use the trailer button) somehow related?
3. Should the red/purple wire from the alternator be connected or not?
4. Since the starter was replaced last year, could this problem be caused by a bad slave solenoid (perhaps related to the bad battery switch/isolator?
Sorry for the long post - and appreciate any suggestions/best guesses as to what is going on and how I should troubleshoot to try to isolate the problem
Don S
Re: Electrical Problems
The trim does not raise the engine, it raises the sterndrive.
Here is how to troubleshoot the trim system.
View attachment A1G2 Trim Troublelshooting.pdf
Here is how to check your starting system.
View attachment Troubleshooting a mercruiser Starting system rev2.pdf
sea2sea
Thanks - (I meant sterndrive... :)
Any thoughts about the disconnected red/purple wire from the alternator?
Don S
It's the sensing wire for the alternator. Plug it back in.
Oops, forgot the diagram.
