Hola <br /><br />I recently moved some wires and loosened the starter to get at the carb for a cleaning. In the reassembly process I could not remember how one of the wires (green braided) between the starter and starter solenoid is mounted (I know, my bad). <br /><br />Specifically, where does one end of the green braided wire connect to the starter? The wire is braided and looks like a hippies bracelet (pardon the analogy). Does the wire directly contact the starter before the mounting bracket where the starter solenoid hangs off the starter, or does it not contact the starter and instead contacts the mounting bracket (directly under the mounting screw and washer)?<br /><br />Sorry so long and complex. Can try to take a pic and post if clarification is needed.<br /><br />Thanks in advance.
