Re: electrical question
1" is barely big enough per NEC. It really depends on the type of wire (THHN, XHHW, etc) and the type of pipe (EMT, PVC Schedule 40 or 80, or flexible metal conduit, etc). Use 1-1/4" minimum. It will pull easier if you go even larger, say 1-1/2".<br /><br />EDIT-also make sure you use a good quality pulling lube. It will make it MUCH easier.
