Scallywag1
- Joined
- Sep 5, 2008
- 19
I purchased a 1976 85 HP, I thought it was worth what I paid for it even as parts. I figured I'd try to get it to run before I part it out. I need to get a control box, and external harness for it before I can do a compression test. The problem is that the internal wiring harness had some corroded wires. I removed the harness, spliced wires, could not solder them due to corrosion had wicked up through the insulation, I butt spliced and shrink tubed everything. When I hooked everything back up I have continuity from the ground pin on the plug to all of the other pins???? When I unhook the black wire that is connected to the block at the rectifier I loose continuity to the other pins. Is this right??? Is it possible the molded plug end could be bad?? I just received a manual for this motor, checked the wiring diagram. Everything seems to be hooked up where it should be. I found an internal harness online for $100, I didn't want to put much in to this motor until I find out if it runs or not. Any ideas?? I thought about getting an external harness and hooking everything up direct to see if I could get it to Fire up. Thanks Kevin
