nineteensixtycaddy
- Joined
- May 21, 2008
- 74
For those of you who are into the wiring,and playing with toys on boats... I've got a few questions.
This is all prompted by my working/playing with my 59 Evinrude Lark 35hp.
First of all, let me start by saying I've played with wiring for some time, mostly on cars, and have a very limited knowlege of how things really work. I sorta understand a generator with an external voltage reguator, and an alternator with an internal volgage regulator, and I know something about fuses and wire size/gauge, and a bit about relay's and switches.
That being said... first question, isn't a starter's solenoid... basically a heavy duty relay? The little wire going to the solenoid, trips the relay, to let the heavy duty positive battery wire, connect up to the starter. I've always wondered why they call it a solenoid, instead of a relay.
Next question. I know how a distributor works, sorta, but I know NOTHING about a magneto. I know a distributor needs to collect energy in a coil, and then "distributes" that electricity into each cylinder carefully timed by a rotating "rotor" how apptly named. So... in a magneto, it appears there are still coils, but one for each cylinder, instead of one for the distributor. So.. each coil builds up a charge, and fires it into each spark plug.. but since no battery is required... the charge comes from a magnet? hence magneto? Do I have that right?
So.... the magneto, requires no outside power, after it's rotating. Hence it needs a short, like the cutoff switch wires, to make it stop running. I get that I think.
My question is... why does a mageto powered engine, need a battery? The evinrude has a battery, going to the starter, and basically just uses the battery to start the engine. And that's all it really is there for right? So... how does the battery get charged?
That's my real question. How does the battery get charged again. I don't see an alternator, and haven't heard of one existing on outboards. And I don't have the "optional" generator that the 59 manual lists. So.. without a generator, or alternator... won't the battery just wear out after 4 or 5 starts, and refuse to turn the starter anymore. I know a car battery can only start a car so many times without being hooked to some sort of charging system, or else it goes dead.
Next question, very related to the previous... if I hook up stuff like running lights, a horn, interior lights, maybe a radio, how does the battery get charged to continue running all this stuff.
I can think of a few options here. Either I need to find a way to get the "optional" generator, which probably has about a 20 amp output, if that, compared to todays 150 amp alternators.
Or.. I need to find a way to mount and utilize a modern alternator and fit it in the hood of the lark.
or... perhaps the easiest method... I can mount two or more batteries, using one to start the motor, and the other to power my accessories, and have a "spare" in case either goes dead while out cruising for a day or two.
Or.. I'm way off base, and somehow the magneto charges the battery, and I have nothing to worry about!!!
Help Please
Help Please
