Re: Electrical - Tilt/Trim function
My lack of knowledge shows again. Mounted on the right pontoon, by the batteries is the "tilt/trim" unit. There are two identical units, side by side. On the front of these there are three bolts with wires attached to each bolt - two bolts above the third forming a triangle. If I put a screwdriver across the top two bolts on the unit on the left, the motor raises - if the I repeat the exercise with the "unit" on the right, it lowers. If this is not the tilt/trim, what is it - what exactly am I working with? I am going to work on the boat this week after work if it doesn't rain - I will let you know if I get it working from the console.
Is this an add-on tilt/trim unit???? I assumed that the relays were in the engine cowling.. While I am not a tilt/trim expert, I have worked on quite a few during my many years of boating. I did have a boat with tilt and trim in the 80's that had the motor, relays, and hydraulic resovoir under a rear seat. So maybe this is what you have.
All of the trim motors I have ever seen had only two wires. The relays worked to reverse the polarity of these two wires. With this senerio, there are no two wires on any one controlling relays that can be shorted to make the motor run. However, there are other DC motors that have two leads. One of them is a forward, one is a reverse and the case acts as a common or it may have a third wire as a common. From your description so far, you must have one of these motors because you can short the contacts of the controlling relays to make the motor run.
I am a retired electrical engineer, so I can and will step you through this problem.
So answer the following questions to help solve this problem:
1. Is the motor near these two relays or is it near the transom?
2. How many wires are on the motor?
3. Can you determine where these wires go and if so, where?
4. Does the bolt that you did NOT short have a smaller wire than the two that you shorted?
5. Does the wire on this same bolt run towards the console?
