Re: electrique probleme
OK sly....your problem may not be in the lower unit. If you have trouble getting rpm with the throttle and have to play with it to get it to go, then it may be a carb problem. Maybe some junk in the float bowl. Have you check the fuel lines to make sure they are all tight and secure? Primer bulb is good and fuel tank vented? Choke is coming open? Here's something to try.....<br /><br />Put some pre mix fuel in a squirt bottle. Have a friend with you. Put the boat on the water. When the throttle is forward and not getting any rpm, squirt some premix into the carb and see if the rpms pick up. If they do, probably a gas feed problem. <br /><br />Also make sure the primer bulb pumps up snug before starting cold.<br /><br />One more thing to try.....look on the front of the fuel pump. The big black cover on it. Remove it and check the fine mesh screen behind it. Remove the hose that goes to the carbs and temporarily attach a hose to the fitting. Have someone crank the engine. You should have fuel squirting out the hose pretty good.<br /><br />Keep us post sly.....
