Re: Electrode burning off one plug
Thats the info we need. <br /><br />First lets check compression to make sure we dont have a damaged cylinder now.<br /><br />If the compression is OK, pop the flywheel off to make sure the key isnt sheared.<br /><br />If the key is good, check the timing on #1 with your timing light. Make sure it doesnt go past 28 at any rpm. Check it as close to wot as you can. If, at any prm, it does go past 28 then shut down right away.<br /><br />Good luck!
